ps2 flip-top cover
ps2 flip-top cover
has anyone used one of these? http://www.thegiantstore.com/index.asp?PageAction=VIEWPROD&ProdID=265&HS=1
does it enable your ps2 to play coppied game's?, back up's of course Wink
ps2 flip-top cover
Yes the swap magic disks allow you to play backups and imports but only work with the flip top PS2. Plenty of them on Ebay btw.
More info here http://www.swapmagic3.com/
ps2 flip-top cover
Yup, mine works flawlessly, just remember to be v. careful of the power/eject ribbon cable while you remove the original cover and fit the flip-top, can be a fiddle to get it in without risking any damage.
Oh, and if you get one, find something weighty to sit on the flip-lid section, they aren't exactly the most perfectly created contraptions and since the flip-lid will contain the little doobery for holding the discs in place while the console is in use, it'll need something weighing it down unless you like un-neccessary noise, a minor flaw though, nothing that the box-set of 24 series 1+2 wont cure Wink
