pings
obitus
pings
hey... ive got a ping of high 200/ low 300 with broadband on jk2 should i be getting this ?? also when try to join a bf1942 it always seems to cut off?? why?
pings
1. whats the usual ping?
2. whats the IP of the server?
3 have you done a ping trace?
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
obitus
pings
well thats only about a hundred better than my 56k connection, i dont no how to do a ping trace and the ip is 207.115.47.113.28070
thanks
pings
Well that IP is in the US of A, so no wonder your getting high pings. Best in game ping I ever had to USA was 120 but avg is 180-250, thats in UT / UT2k3
pings
I often get people from the states on our UK based mohaa server (217.158.176.31:12203). Their pings are in the >150 range normally.
Try using all seeing eye from
http://www.2ndrangers.co.uk/modules.php?name=Downloads&d_op=getit&lid=16
It will show you the servers with good pings for you.
Malc
