ping problems
ping problems
Hi, i joined plusnet about 1week ago, i am very happy with the service its excellent, thank you plusnet! but i have one slight problem, when i play online my pings like 40+ sometimes you have people on there with AOL ADSL connections wopping my ping, and i dont like that Evil i was hoping for a ping of like 20ms to good servers that i play on, not like 40-100ms is there anything i cud test to see if its my end or plusnet's?
Thanks Wink Tongue Smiley
ping problems
If you've got an internal or a usb modem, buy a router/modem, then connect your computer to the router/modem using a nic.
Your pings will improve.
ping problems
Yeah i have a external usb green fishy modem, what are the adverage ping on plusnet? if you have a router could you post a ping test to jolt.co.uk
Thanks Smiley
ping problems
I get an average of 15ms to Jolt, and that's with using a broadband router over 54g wireless.
Thomas
ping problems
This is my ping test from my client pc using the green froggy:
Reply from 195.149.21.11: bytes=32 time=22ms TTL=58
Reply from 195.149.21.11: bytes=32 time=18ms TTL=58
Reply from 195.149.21.11: bytes=32 time=24ms TTL=58
But these pings are as low as ive seen them for ages, + when it says i have the highest ping of 24ms, when i actually play on the server, i never get pings lower than 40ms :x
