et-files.frag9.net no permission to access
I cannot access http://et-files.frag9.net/ connected to plusdsl.net.
Can you fix it?
What is that link? Your webspace or just a web site you cannot access?
When clicking on the link I cannot access it either.
If it is anything to do with your web space use the contact us link and report the problem to PlusNet and ask for it to be investigated.
csogilvie
I can access the link fine from here... there are 2 seperate 258MB files listed.
I assume this is one of the game servers. Do you have to be a member or join something to be able to see or access the link given?
I don't play on-line games so this may explain why I can't access the link.
csogilvie
Neither do I, in fact I dont' even play many offline Smiley
Hmm. strange, when I click the link I get:
Forbidden
You don't have permission to access / on this server.
Apache/1.3.28 Server at et-files.frag9.net Port 80
Is this what you are getting rooibos?
Ya thats it.
http://portal.plus.net/central/forums/viewtopic.php?t=6705 says the Wolfenstein download is available from the link - I was looking for a quickstart online game to test my new connection.
same here
I don't suppose they've put something in the .htaccess file which means only PlusNet/Force9/Free-Online IP ranges can access it? Maybe you're on a certain range which hasn't been added?
The ET files where setup prior to the new IP block being assigned to PlusNet.
This sounds like that block has not been added to the ACL in that dir.
I have sent Josh Berry an e-mail to get this resolved
That would explain it, I'm a new PlusNet customer so probably have one of the new IP ranges. rooibos may be the same.
Yep, a quick "resolve" and it appears you're both on the same range.
jberry
This is because I forgot to update the access list with our latest IP range Shockedops: . I have now done this so if you can have another go and let me know if you have further problem.
I will also get around to uploading the patches for the game as well in the next couple of days.
Regards,
I can see the files now so rooibos should have no problems either.
thanks to all. i'll soon be running around arnhem saving the day from the gerries and whatnot
