enable punkbuster
enable punkbuster
hi all am trying toplay quake 4 on line but most servers say punkbuster must be enabled so went into the settings [ur player id etc and punkbuster is disabled but it wont allow me to enable it i click on it but it stays disabled ,do i need to remove q4 then reinstal and if i do i;ll lose my saved games [just at the bit were u fight all the creatures in a locked room [think its near the end so i dont want to lose this bit ] or can i saveit elsewhere [maybe another flder then reinstal it to q4 if i reinstall the game ]
enable punkbuster
try going into your program files, finding the pb folder, delete it, and download
PBSETUP
http://www.evenbalance.com/index.php?page=pbsetup.php
Its a new way of updating punkbuster, also if punkbuster isnt there it will install it, I did it for my BF1942 when I forgot to install PB, it will install it and keep it up to date once you run it once in a while, it will actually update all your PB related games.
Try this BEFORE you go for the complete uninstall
many thanks
done that worked a treat many thanks if only my gaming online was as easy Cheesy
enable punkbuster
no worries mate, glad it helped!
