cs 1.6 help!!!
cs 1.6 help!!!
I have a BT 2110 router.... been on portforward.com, which is great and helped with WC3, but allas nothing worked regarding steam.
I can connect to games no problem... it seems to be when the 2nd pc connects.
When 2 pc's connect to cs (clan war) all is fine for 20 mins or so then all of a sudden BAD ping spikes and cl_flush entirty packet crap pops up and both pc's close cs?
Has this happend to anyone else?
I have changed the ports that cs connect to on steam (+clientport 27005 etc) and followed the portforward site but still the same....... i need help
thanks in advance
Gaz
1 REPLY
cs 1.6 help!!!
Lo,
this worked for a m8 of mine on a wireless netgear router, but maybe worth a go for you.
Disable your wireless zero configuration in services.msc on both pcs.
heres a quick google result on "how-to" clicky-clicky
If your worried about disabling services, just google it, there are loads of sites offering info on each one and what they reccomend Cheesy
GL + HF
