connecting to the net
after getting my xbox 360 for christmas i can not connect it online.i only have a voyager 105 modem and dont know a great deal about computers.one friend has said if i get a netgear dg834 modem router it should work. does anyone know if that will workHuhbecause i really need to get online and kill some terrorists on vegas and be all ready for whenhalo 3 comes out. any advice?Huh
1 REPLY
Plusnet Staff
Plusnet Staff
I haven't got a 360, but my original Xbox works fine with my DG834G (even via wireless) and many others use this router with the Xbox 360 so it should work perfectly fine.
If you've got a network card on your PC you should though be able to play the Xbox using Internet Connection Sharing within Windows, there's a guide here:
http://www.plus.net/support/broadband/broadband_gaming/xbox_connection_guide.shtml
