connecting to XBox 360 Live using Voyager 105 modem help
im trying to figure out how to set this up using:
XBox360
1 x ethernet cable
1 x voyager 105 modem
1 x toshiba equium mx40 laptop
so far i have plugged ethernet cable into xbox then into laptop
set up laptop connection wizard for local connection
started "Test Xbox Live Connection" on 360
ive passed Network Adaptor & IP Address tests but fail on te 3rd test for DNS
please help me befoee i go mad
thanx
mac,
I don't have that modem but if you can add static DNS into it then add
212.159.6.9
212.159.6.10
and do the same on your 360.
i just tried ur suggestion turrell but no joy im afraid :-(
anymore suggestions anyone, im getting desperate lol
Are you sure you've enabled internet connection sharing?
Control Panel > Network and Internet Connections > Network Connections > Right click on connection > Go to advanced tab > Make sure 'Allow others to share this connection' is ticked
This is usually the problem with my mates any way Wink
thanx again but nope it aint that either GRRRRRRRRRRRR!!
haha
I would just buy a new modem/router to tell you the truth. I use a Netgear DG834G
wireless modem router to connect to Xbox live in conjunction with the official Xbox360 wirelss bridge and it works brilliantly. It also took me only 15m to set the whole lot up.
I Smiley
Forgive me if I am wrong.. But wont you need a crossover ethernet cable?
Or is that what you meant by ethernet cable.
---update
The Xbox supplied cable is not a crossover cable, which means you can only use it to connect from a Hub to a PC/Device. If you want to hook up without a hub you need a crossover cable.
http://www.morecomputers.co.uk/textra.asp?pn=F3X126B10M
Winner
Not necessarily...
It depends on whether the Ethernet port on the laptop or Xbox is auto-sensing - i.e. it will work whether you use a x-over cable or not.
Many of the newer routers and NICs and laptops can do this so a x-over cable is rarely needed with new equipment.
I'm not sure if ether the Xbox 360 or the laptop has an auto-sensing port but only one of them needs to have it.
In this situation I would recommend investing in a router anyway, that way you can use your Xbox without your laptop being on.
Yes Peter is right its auto-sensing so you dont need a crossover. I was getting confused with the old Xbox obviously Shockedops:
Ah well, I did try! Wink
I didnt even know about auto-sensing.. Man I am living in the past lol
as far as DNS settings go i leave my PC alone and set the xbox to manual using the settings suggested by plusnet
Primary 212.259.13.49
Secondary 212.159.13.50
ady
i only got this to work with xlink KAI ( or whatever it was called) anyway it was virtual lan
i never got it to work with xbox live tho
