can't connect to any games servers
Hi all
Been with Plus net about a week and a bit now, does anyone else have problems with connected to any HL2, CS:S or any of the HL2 mods servers, not just the plusnet ones but any of them?!? It seems that the server list refreshes fine, but when I try to connect to a server that looks good the refresh for that server jumps from like 30ms to over 1000ms but it never even manages to connect the server. Mental I know but I've checked all my firewall settings and the security settings on my router, not a thing. Does anyone else have these problems, or do I have to enable something in my plus net account? I'm on the Business Premier 2Mb with a contention of 30:1 so I should be getting some excellent speed.
1 REPLY
Its possible you need to redirect certain ports on your router for inbound/outbound connections by the game.
Have a look around on the web and you should be able to find the ports that are often needed in order to connect.
Hope this helps.
