ati 9800 pro ?
ati 9800 pro ?
Hi guys. I want this graphics card luked around and found it for about 120 quid maybe a bit more. Just asking ur opinions on it.
Its 128mb ddr
ati 9800 pro ?
The actual manufacturer is one of the most important features of the card, do you know who makes it?
ati 9800 pro ?
here is the link
http://www.lowestonweb.com/Products/DisplayInfoMain.asp?e=2F99A0AD-B9A8-470B-B643-2A672531F699
Another link here 2
Click here
[Moderator's note (by Chris P.): Link edited as it was stretching the layout]
ati 9800 pro ?
For that price a 9800pro no matter who makes it is good, but would look for a saphire branded card myself.
ps overclockers beware them, google them and read the bad reports if something goes wrong and you have to return anything
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
ati 9800 pro ?
I make regular returns to Overclockers without issue.
I once had to quote consumer law on one case, which they claimed was down to sombody new at the firm, but others never an issue.
Can anybody show me those bad reports?
ati 9800 pro ?
google result1 result2 as requested
ati 9800 pro ?
So try and luk 4 the shappire or how eva u spell it. Nice 1 guys thanks
ati 9800 pro ?
Another questions. My mother board manual says agp slot 4x and on that graphics card i said thats say up 2 agp 8x. Can i use this card or no?
ati 9800 pro ?
Yes, provided the voltages for the port matches the cards voltage.
The only thing is that you don't get the performance of AGP 8x, only a maximum of 4x.
ati 9800 pro ?
AGP8x is backwards compatible with AGP 4x slots.
ati 9800 pro ?
thanks yall but now i have thought about it, i might be able 2 get a new motherboard now. 1 i want is only 50 quid from uk games.com. But it only has 3 ram slots which is ok i guess
ati 9800 pro ?
3 ram slots is pretty standard - another important ram-related thing would be the maximum ram capacity (how much ram can it handle). A lot are around the 3gb these days I believe.
ati 9800 pro ?
Yeah its 3 gig max which is good cause i dont really instend 2 go above 1gig really in the long run. Another question just came 2 another site and they have motherboards at good prices. I came across socketA amd m/board and slotA amd. I guess i wud need socket a. I am new 2 all the insides of computers just want 2 make sure i get it all correct.
ati 9800 pro ?
Forget the slot A, that is a very old AMD technology and should not be sold anymore.
ati 9800 pro ?
Nice one guys u no it all. How will i no if the motherboard will fit my pc case or will it just fit. Thanks
