Xbox live - quick query
When you choose the direct connection, do u have to used a combined router/modem or can u just use an ehternet adsl modem?
The direct connection only works if u have cable broadband such as ntl blueyounder. The adsl such as plus.net, you use ics sharing or router connection. Not 2 sure how 2 use the router connection but ics is simple and works fine. Not 2 sure u can get ethernet adsl modems can u?
Yes you can.
The Xmodem is one such device, and a very good one too.
