Xbox live help
Xbox live help
i Just can't seem to get it working i get this message:
Network services (DHCP or PPPoE) were not found.
I've checked the cables, left the modem of for a few minutes.
I'm using a USB modem and using the netword card, please help me if you can Smiley
Thanx
Xbox live help
what operating system are you on?
Xbox live help
Windows Xp home
Xbox live help
I have windows xp pro and i am working fine r u running ics. well if u r this is what u need to do. go 2 control panel network options. Then right click on your wip tech under dial up then go to properties. Then advanced. then a list of things will of tick boxes. Click the on were it says allow other computers 2 connect through this computer. U require a cross over cable to make this work as it says on xbox.com/uk
