Xbox Live and Direct Ethernet Modem Connection
Has anybody got this to work via Plusnet yet :?:
i think thats what i have mine set up as... i have an ethernet card in the PC but my plus net modem is USB.. i used a crossover cable and its worked.... it wouldnt at first but thats because i hadnt activated the ethernet card to be used in the pc.... (me and technology dont mix!)
if you still have probs let us know.. maybe hubby can figure out what weve got different to you. Smiley
Please state what ADSL hardware you are using (full make/model) and how it, your Xbox and if necessary your PC are interconnected as the titl or you post give no clues as to how your systems are setup. We may thn be able to offer some advice.
I also suggest you use the forum search for XBOX as there are many threads around about connecting it up.
Like one of those?
If your using ics via xp its easy to set up
