Xbox Live and DHCP problems
I haven't been able to connect to Xbox Live on my 360 for over a week now!!! I finally called up Microsoft and after running a few tests they told me that my the DHCP on my braodband conneciton had been disabled and that I need to contact my Braodband provider and tell them to enable it for me to be able to use the 360! God only knows why this was suddenly disabled as I have been happily using Xbox Live for nearly a year with no problems!
Anyway, there is nowhere in help & Support for me to flag this up, so I tried calling and was on hold for over 30 mins before I hung up! I tried again an hour later and was told I would have at least an hours wait!!!!!
Is there any other way I can get his enabled without using Plusnets "support" tool?
Has anybody else had this problem
Sami
Slick
could try sending them a ticket to save time on your phone
once they answer you will recieve an email,
just a thought but is it a router setting?
I think I have done that- I've left ran a service checker and left a comment asking them to enable it- but that was on Thursday and still no reply!
sorry about this but i am thinking about buying an xbox 360 i have this broadband all i wanted to know is does it cost extra on your phone bill or is it included with the subscription you buy
thanks to anyone that can help
scott
It doesn't cost you any extra - although you have to pay Microsoft for the privelage of using Xbox Live.
so i can play for as long as i want and still no extra will be added to the phone bill
Yes.. but if you are using a "pay as you go" type broadband product, obviously it will count towards your usage for that.
i have the 14.99 a month option so i should be fine thanks to all for the help
