Xbox Live - Setting up with PlusNet
bevnet
Anyone...
Is there anything special to do when setting up your xbox live setting when connecting via a router rather than using internet connection sharing via a PC Huh
I was just going to leave everything as automatic.. My router uses DHCP as well, so can assign an IP (192.168.x.x).
Do you have to do anything with PPoE with the Xbox Huh
Cheers
Ian
Not sure how to set up a router connection. I think its all automatically done not sure sorry
If your router is setup using DHCP then you shouldn't have to enter any settings (as the XBox should be able to determine its own IP, DNS, etc. settings).
You may need to add some port forward (inbound) rules to your router as well for certain on-line games.
