Xbox Live - Fails on IP Address
jgardner
I'm trying to connect to Xbox live but it won't connect, and when i use the troubleshooter, it fails on IP Address. Can anyone give me some ideas on how to fix this?
At my wits end now.
First thing to try is a simple reboot of the router.
jgardner
I'm not using a router, i'm using a modem.
FooAtari
A modem? So you must be using Internet Connection Sharing? The Xbox has to be either connected to a router or a through a PC, you cant (to my knowledge) connect it directly to a modem.
The IP and DNS on the Xbox should be set to the IP address of the PC or router it is connected to.
Is it a 360 or Black Xbox?
