Xbox Connect ping problem
I use Xbox Connect to connect play halo 2 against others
This program tricks the xbox into thinking the other peoples' xboxs are on the lan so you can play through system link
Yesterday I tryed hosting a game
From the lobby of the game (in xbox connect) other peoples pings were 800-100+
I have 1mbps
Any help much appreciated
How many people did you have in the game ?? Cause you only have an upload of 256k. We in uk cant hold to many players when hosting
I only had about 4 people in it
Also the pings only seemed to jump once the game actually started
There shud be no problem with 4. Could be a problem with plus net at the moment. Just keep checking it to see if it gets any worse
calpe,
How is your connection setup? were you using your PC for anything at the same time, i.e downloading, P2P?
4 should be no problem as Extreme17 has already said. Cheesy
Unless xbox connect has gone really rubbish lol
1. No I wasn't using anything at the same time
2. My setup...
My Computer - - - - - - - - - - - - Router - - - - - - - - - - - - Xbox
Both cables used are patch and the router is set up using DHCP
I have also opened the required ports in my router
Do you use xbox live. If not you might want to invest in that as its good. And probley more stable
Mmm, why do you think i'd be using XBC if I have XBlive
Its also extra money on top of your BB subscription.
Anyway, why should you use a pay service if there is one almost as good for free
40 quid a year oh know lets start thinking of geting a loan. Xbox live is more stable and less hassle then xbox connect. When eva i used it there was a problem with my mates connecting always a problem. Xbox live no problem. Dont have a go mate only surgesting things not hear to argue
Fair enough, but the thing is, for some of my m8s it's the other way round. They have broadband setup to their computer (USB Modem) and use ICS to share it to their xbox but they just can't get xbox live whereas xbox connect works fine!
Thats werid as i use ics and it works fine.
I know, its odd because i've tried ICS even though I don't need it (I have a router) and it works.
