XBox - Direct connection
I'm not really interested in hooking the xbox up to my pc but i would like to know if the A360 USB Modem has the necessary reuqirements to work with the 'Direct Connection' style from:
http://www.xbox.com/en-GB/live/start/connect/direct/
I don't think so as that guide talks about the modem having an ethernet connection, but as far as I know the A360 has a USB connection.
Thanks for replying,
Could anyone recommend a 'cheap', modem wth the ethernet extra that would be suitable?
If i were you, i'd use Internet connection sharing.
Buy a cheap ethernet card from www.ebuyer.com and a crossover cable. Connect your xbox to your pc, and your set.
I want the xbox to be downstairs though. Don't think my pops wud be too please if I knocked a hole in the ceiling :p
Although costly to setup, you could go wireless
I'm not fussed with having it intergatred with my pc or this necessary for the xbox to work with plusnet?
There is no need to have it intergrated with your PC. For Xbox, you don't need a PC at all.
However, if you wish to stick with the USB method, you will need to use internet connection sharing on the PC, and connect the Xbox to the PC with a ethernet cable.
This will then require the PC to be switched on and connected to use the Xbox.
With a router option, the router takes care of all the connection, so any ethernet enabled device can access the internet, including rh Xbox.
This will remove the requirment for the PC to be on, and rotuers use far less power.
Going wireless with a router will mean that no cables are needed. It shares the internet connection accros multiple ethernet enabled or wireless enabled devices.
Thanks for your help
