XBOX help
XBOX help
hi trying to set up my xbox but get stuck on my DNS could some help please
Moderators note by John (johnessex) Topic moved to a more appropriate forum
XBOX help
I don't know the x box however the dns for plus net are 212.159.6.9 and 212.159.6.10 if thats any help
XBOX help
How are you connecting your Xbox Up? via a router? or ethernet modem?
There are number of DNS servers on PN, but those listed previous are the ones for dial up, but will work.
XBOX help
going throught a moden no router or pc. i now think that my new modem that i got today might not work but please help so when i get my new one it will help me thanks
XBOX help
I think your modem probably does work, are you using it on your PC?
I would imagine one of your settings on your Xbox needs adjusting
XBOX help
You need to set up ics sharing and you require a crossover cable. Have you enabled sharing through the network card on your pc?
