XBOX 360 Project Gotham 3 & NAT issues
Hi guys,
Had Xbox live working fine with my Broadband for months now, & it works fine with PGR3...........
That is until I try to get onto the tournaments & it gives me an error to say that my NAT is incompatible with PGR3 tournaments, and says I need to change it ??
Any ideas on what to do ?
Chris
Anyone ?
have you tried any of these?
Turn on UPnP
Port forward-
UDP 88
UDP 3074
TCP 3074
Or as a last resort add your Xbox IP into the DMZ.
Cheers mate - will give these a go tonight !
No problem Chris.
Let me know how you get on. Forwarding the ports is the one that normally does the trick.
