XBL
XBL
Would XBL work with this equipment?
1. Xbox (Obviously)
2. Kit & Subscription
3. Plusnet ADSL
4. Direct connection choice using this modem/router: http://www.usr-emea.com/products/p-broadband-product.asp?loc=unkg∏=bb-scrtr-adsl
5. A phone socket with micro-filter
NB I dont want it hooked up to the PC
1 REPLY
XBL
Yes, this will work.
However, both your current USB modem and this modem will not operate on the line at the same time.
They will however, work seperatly.
The fact this is a rotuer means you could possible throw the USB modem in a draw, and only use ethernet.
Placing a wireless access point in to this system in the future will allow you to make your XBL connection wireless.
