World of Warcraft Pings
Hi Folks
Anyone else experiencing high pings in World of Warcraft since yesterday?
ST
my wow gaming experience has been awful lately.
i regularly get disconnected, have lag spikes, high latency and yet when i ask in guild if anyone else is suffering from similar problems, they're not.
i know blizzard isn't (always) blameless. i'm looking on these forums to see how anyone else is fairing with wow and if it looks bad, i'll probably be leaving plusnet very shortly.
Same here man. Since yesterday ive been haveing 2k Latency at around 5pm till 9ish.
Aint too good when yer raiding TE and yer lagging in mid Teleport Sad
It's awful for me too.
Yeah same for me guyz, mainly for the last week or two its been up and down, but now its constantly high. Pings between 300 ish when im in a low populated area, but once i go do something like molten core with 40 ppl my ping (like last night) was averaging 1300ms+
A trace route isnt clear though in this situation as it comes up with low pings:
Tracing route to 80.239.178.116 over a maximum of 30 hops
1 1 ms 1 ms 1 ms voyager.home [192.168.1.1]
2 24 ms 37 ms 23 ms lo0-plusnet.pte-ag1.plus.net [195.166.128.64]
3 23 ms 24 ms 23 ms ge0-0-0-403.pte-gw1.plus.net [84.92.4.1]
4 24 ms 25 ms 26 ms 195.50.117.169
5 24 ms 24 ms 23 ms ae-22-54.car2.London1.Level3.net [4.68.116.112]
6 24 ms 24 ms 24 ms telia-level3-ge.London1.Level3.net [4.68.111.182
7 23 ms 24 ms 23 ms ldn-bb2-pos6-1-0.telia.net [213.248.64.49]
8 32 ms 31 ms 33 ms prs-bb2-pos6-0-0.telia.net [213.248.65.114]
9 30 ms 31 ms 33 ms prs-b2-pos11-0.telia.net [213.248.65.226]
10 33 ms 31 ms 31 ms prs-tc-i2-link-telia.net [80.91.250.34]
Its feeling like that problem Plus.net had back in january where alot of people had high latency in the evenings (although this is 24/7), i'm guessing some sort of filtering port on plus.net is causing the problem.
i'm on the terenas server. nothing at my end has changed hardware or software and it used to play just fine.
i know blizzard patched recently and it was awful the day after that, but guildies are all fine now.
my tracert shows 25ms all 9 hops right up to what i'm assuming is blizzards boundary firewall/screening router (whatever it is) but i'm guessing if traffic is shaped, this probably wouldn't show up in echo requests? i say that because no-one else complains of latency and when i do, tracert still shows 25-30ms all the way to hop 10.
I started getting this yesterday. It went up to almost 9k ms at one point! I don't think it's PlusNet, I can ping websites etc just fine, the problem is only with WoW. I've tried rebooting my router which doesn't seem to help. On the whole I usually get very few problems with latency - this is very frustrating!
Here are some screenshots of a Tracert they asked me to run, and at the same time the ingane latency
http://private.wotton-pcs.co.uk/wow_pings.jpg
http://private.wotton-pcs.co.uk/wow_pings2.jpg
http://private.wotton-pcs.co.uk/wow_pings3.jpg
[Moderator's note by Daniel (no7olivier): Changed images to links as they were severely streching the page.]
Ajtame
Just out of interest does anyone get random disconnects that arent actually disconnects? (connection definately not going down and not losing sync)
It appears that the connection just freezes up while in game? you get disconnected then before you know it you can just connect again straight away without issue, this happening say 3 or 4 times an night only in the evening?
PhillipH
my wow has been friggin so bad latency/lag its nearly unplayable!! and this is only the past week.
im not even going to bother posting pings and things like that, its annoying me so much im just going to move provider.
and yes ive tried changing router/filter/putting directly into socket etc, its just as bad.
I've had a similar problem since yesterday morning - high latency with even higher spikes, plus a lot of random disconnects. It was perfectly fine on Friday evening, and every other net service including other games still functions as normal. All the time, my net connection stays up and other things such as streaming radio aren't interrupted - it's just the game I disconnect from. I can reconnect again, but straight into the lag again.
It's just WoW that's suddenly become afflicted, and I'm not clued up enough to tell if it's ISP or Blizzard related. A colleague suggests it may be some P2P tech that the game uses which is suddenly being blocked, but again I can't say if this is right.
I've been getting disconnected but from the entire internet, while remaining sync'd.
Yes, I used to accept this as part of online gaming but recently it happens every other night.
What happens for me Mr PN dude is I can play the game then all of a suddon I get insane Lattency. 1-2000. The game lags up, haveing 1-60 seconds lag. I can see people moveing, some talk in Guild Chat but I cant talk back due to lag.
It usaly happens around my raiding time. 6pm ish till 9pm ish - 11pm.
Today, its been worse of all days. 2 times I have had to reset my modem to play a few hours.
VERY bad lattency this morning. Cant even log in. 3000 latency. If this carrys on .. I will have to move ISPs
PhillipH
im go back on my word, here :
Tracing route to host-97.wow-europe.com [80.239.179.97]
over a maximum of 30 hops:
1 <10 ms <10 ms <10 ms 192.168.0.1
2 43 ms 47 ms 44 ms lo0-plusnet.pte-ag1.plus.net [195.166.128.64]
3 66 ms 44 ms 43 ms ge0-0-0-403.pte-gw2.plus.net [84.92.4.2]
4 45 ms 44 ms 47 ms 195.50.117.169
5 46 ms 45 ms 43 ms ae-12-53.car2.London1.Level3.net [4.68.116.80]
6 45 ms 43 ms 43 ms telia-level3-ge.London1.Level3.net [4.68.111.182]
7 44 ms 47 ms 44 ms ldn-bb2-pos6-1-0.telia.net [213.248.64.49]
8 50 ms 52 ms 51 ms prs-bb2-pos6-0-0.telia.net [213.248.65.114]
9 50 ms 52 ms 51 ms prs-b2-pos11-0.telia.net [213.248.65.226]
10 187 ms 200 ms 199 ms prs-tc-i2-link-telia.net [80.91.250.34]
11 * * * Request timed out.
12 * * * Request timed out.
13 * * * Request timed out.
14 * * * Request timed out.
15 * * * Request timed out.
16 * * * Request timed out.
17 * * * Request timed out.
18 * * * Request timed out.
19 * * * Request timed out.
20 * * * Request timed out.
21 * * * Request timed out.
22 * * * Request timed out.
23 * * * Request timed out.
24 * * * Request timed out.
25 * * * Request timed out.
26 * * * Request timed out.
27 * * * Request timed out.
28 * * * Request timed out.
29 * * * Request timed out.
30 * * * Request timed out.
Trace complete.
Now talia.com is wow's ISP isnt it?
