Were to rasie a ticket for a game.
BenG
hi I like to know were I can request help for a game, I play an opensource game called Cube and been seeing large pings. I herd ppl say raise a ticket but not seen were to add it so I hope this is ok to put it here.
I read some of the game config files and all the info I get back is this.
Cube Engine Game
Default is a non-dedicated server with only a single client. Dedicated servers run in the shell only (no graphics), with increased priority yet use very little cpu time & memory, so you can run one in the background, or at the same time with a client if you want to host a game. Server port is fixed at 28765, with 28766 being used for the server info requests (both UDP).
Sauerbraten Engine Game
Same info as above but the ports are 28785 (UDP) and 28786 (UDP).
also in the game I it downloads a small server.cfg file, that has a few IP address so here are the IPs if they help
Cube IPs
87.88.137.213
85.25.55.231
85.119.156.220
83.142.229.198
75.117.243.56
206.246.124.124
193.66.231.253
Sauerbraten IPs
81.169.138.14
212.62.95.86
85.214.84.157
85.176.212.6
83.204.245.66
68.116.23.170
65.188.200.30
207.210.96.215
85.210.146.233
24.192.115.69
80.219.145.107
193.24.244.72
194.153.87.204
88.198.9.140
85.25.52.187
85.25.139.83
Thank you.
jagger
Straight above this message is a section called help and support.
Go in there and then click on "My Questions".That's where you raise a problem with the customer services.
Don't hold your breath.
BenG
Thanks for the info, I give that a shot latter.
