Virtual drive help
Virtual drive help
I am getting fed up with changing DVD and CD gamer disc's all the time, I believe you can buy software that allows you to store your games onto hard disc. I think the term is making a virtual drive? If so which is the best software for this task, please.
Virtual drive help
Alcohol 120%, first you will want MagicISO though to create an ISO image of the disk, then Alcohol allows you to mount the image on to a virtual drive.
Although some games do have protection against this and there isnt much you can do without some pretty illegitimate software :roll:
Virtual drive help
I like Daemon tools for doing what you want.
crimsone
Virtual drive help
The other option is NeroImageDrive, which comes with, suprisingly enough, Nero.
Unfortunately though, on many games these days you'd need to either be very good at copying games and bypassing protection (though I don't see the protection is fair for this sort of ligitimate use), or you'd have to use a no-cd crack for the games in question, which often come from dubious sources. I guess if you own the game the choiuce is entirely up to you really.
I can also highly reccomend daemon tools though Smiley
