Updating MOHAA
egor44
Updating MOHAA
Hi All, I have MOHAA (original), but am unable to update it using the USA/UK patch , so am unable to play online. Does anyone know any tricks i should be doing to allow the update to work. I saw something about changing a byte in the registry, for usa it was 1 and uk it was 0, but my game is not using the same registry path.
Any help would be appreciated, TIA.
Ken
espresso_mick
RE: Updating MOHAA
Are you sure you have got the USA/UK version of the game?
If you can't get the patch to install you could always use gamespy and filter the servers so that only version 1.00 games will appear in the list.
Phantom_Flan_Fl
RE: Updating MOHAA
You shouldn't need to change anything in the registry for it to work.
Where did you download the patch from??
I don't suppose there'll be many 1.0 servers available nowadays.
espresso_mick
RE: Updating MOHAA
There are still a few.
egor44
RE: Updating MOHAA
I downloaded the patch from EA Games, about 5 times :-)
I have now edited my reg entery, and added one 1.1.12.200 , my previous was 1.2.1.190.
The update has now taken although, i think it may be german now :-)
I havent really checked it out as now i cant find my cd :-)
I may still uninstall, remove entries from the registry and re install again. I dont believe it should be this difficult to update a game, and I may have upset it playing in the registry.
Did your's update with no problems ??, straight from the box (so to speak).
TIA, Ken
RE: Updating MOHAA
Yep mine updated no worries straight out of the box. I would recommend finding that cd and doing a fresh reinstall. Sounds like something may have been corrupted.
cyas online
Homerlovesbeer
egor44
RE: Updating MOHAA
Cheers All,
I am going to do a re-install and take it from there.
Hope to see you all on the floor soon :-)
TTFN, Ken
RE: Updating MOHAA
> Ken
Hi Ken
Huh changing a byte Huh??
if your game key starts "4500" then there should of been no problems with the usa/uk patch also there is a new Europe patch version 2.11 54.4MB
