Unreal II help needed
Have got stuck in Unreal II
Got all the way through the first building got down in to the power generator by jumping in from the top. The guy I was supposed to save got killed but I got the alien artifact, a message comes up on screen saying to leave the power generator but I cannot find a way out - I then get killed by a hard to kill guy Evil How do I get out of the generator?
Is there a way to display the frame rate on screen :?:
Tom
i can't remember offhand but i think once you kill the bad guy(try alt fire) you automatically exit to a cut scene.
Don't know about framerate
Yes once I killed the bad guy the doors were opened so could get out OK. He was so nasty that escape seemed a better idea.
Tom
hmm in Unreal if it moves you have to kill it, theres only very few exceptions to that rule but they are blatanly obvious when you get that far.
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
