UT2003?
UT2003?
With the servers now being listed as UT2004, does that mean there are no ut2003 servers any more? (I know I should upgrade, but the demo runs at all of 3 frames per second on my system).
TIA
jberry
UT2003?
Yes, when we were upgrading the servers we decided to move all the 2003 servers to 2004 as it was much more popular (due to it just having been released).
Re: UT2003?
TIA
I was the one that pushed for all the servers to move to UT2004 as basically epic stopped supporting 2003 as soon as they had released there new game.
You shouldn't have any noticeable fps difference between 2003 and 2004 for the gametypes that were in 2003 (DM, CTF, DDOM, BR)
If your not able to run the game at a decent fps on Onslaught and Assault, thats undestandable as the maps are much larger and complex than the smaller maps.
All I can suggest is if you've got less than 512mb of ram, upgrade to atleast that amount (for a cheap way to help improve performance).
