Teamspeak trojan warning
if any of you are using mcafee antivirus then it will detect a trojan within teamspeak,this is not a trojan but a conflict between mcafee and ts.ts have realeased a fix for it and mcafee is about to realease an update to rectify the warning.if u allready have deleted the dll file then download the zipped file from ts developer and paste it into ur ts folder.http://www.teamspeak.org/forums/sho...68&page=2&pp=15
1 REPLY
same applies for most antivirus software, just go back to teamspeak home page and dl the small patch and things are back to normal. Smiley
