Teamspeak help
Bojangles
Teamspeak help
I commonly use teamspeak to communicate with people. It has worked fine for years but recently i have been unable to connect to the server. I know that the server is working as people have told me they can connect to it.
All my other internet applications work fine. According to the teamspeak site, forwarding ports is only required when hosting a server. Which makes sense seeing as it worked fine for years.
Has anyone had this sort of trouble? If so please help
Thankyou
*Problem resolved, thanks*
1 REPLY
Teamspeak help
go into dos and try and ping the teamspeak server address. If you get no reply then it's probably going to be a firewall issue.
