Static ip for ps2
Static ip for ps2
I am trying to setup ps2 to get online. I have a static ip address and I key in all the details correctly when setting up.
When the ps2 does the diagnostic test it always fails on the dns server thing. Any suggestions as to why this happening?
Static ip for ps2
i have a ps2 online and it works great
if you tell me a little bit more about the connection i might be able to help
dnas is a security check from sony if you have modchip installed unless you can disable it it wont work
Static ip for ps2
are you connecting via a router or through a pc using internet connection sharing or a dedicated ps2 dsl modem?
