Problems with voice comm. CS1.6
I play CS 1.6 on Steam and i recently bought a mic and headset. Unfortunatley it doesnt work and i get really choppy sound. Does any one else have/had this problem because Valves forums offer no help and Im thinking it might be a problem with PlusNet connections as my m8s mic works fine (on BT Broadband) and he lives just down the road.
HELP!
jberry
This will not be a problem with your connection (or if it was you would see other side effects such as high pings, lag and slow speeds). Its more likely to be equipment - try your equipment at your mates house or his at yours and see if the same problems occur.
Regards,
Yeah, its not connection coz i got 512k and it never lags or pings out in games.
Of course you are right about testing it somewhere else and i cant believe i didnt think of it! ty very much.
Oh also i heard choppy mics might be casued by firewalls does anyone now what ports need to be opened up for voice comm. to work?
