Problem with high ping
Hi there, I am having a problem with a high ping on certain e-frag servers and I have been told to come here to ask about the problem
Info about the problem can be found here - http://e-frag.co.uk/forum/showthread.php?p=25928
Tracert of problem
Thanks for any help.
jrgrahamcov
I have just tried pinging the address and get response times of around 20ms which is fast. Can you try and ping it now to see what response times you get.
C:\Documents and Settings\Simon_>ping 83.142.52.53
Pinging 83.142.52.53 with 32 bytes of data:
Request timed out.
Reply from 83.142.52.53: bytes=32 time=53ms TTL=54
Reply from 83.142.52.53: bytes=32 time=35ms TTL=54
Request timed out.
Ping statistics for 83.142.52.53:
Packets: Sent = 4, Received = 2, Lost = 2 (50% loss),
Approximate round trip times in milli-seconds:
Minimum = 35ms, Maximum = 53ms, Average = 44ms
jrgrahamcov
Thats doesn't seem right. I pinged it again and got :-
Reply from 83.142.52.53: bytes=32 time=15ms TTL=56
Reply from 83.142.52.53: bytes=32 time=17ms TTL=56
Reply from 83.142.52.53: bytes=32 time=16ms TTL=56
Reply from 83.142.52.53: bytes=32 time=19ms TTL=56
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Minimum = 15ms, Maximum = 19ms, Average = 16ms
I would log a call with the helpdesk and get them to take a look at it.
When playing games things that can affect your ping are :-
Running Antvirus software
Running a software firewall
Downloading things at the same time as playing on line games.
Hope that helps.
