Pro Evo 4 Screen freezes on XBOX LIVE
Hi guys,
When playing Pro Evo 4 on xbox live, the gameplay is terribly jerky and at times the screen just freezes for approx 15 secs (by which time more opponents equalise or get a goal back Cool ).
Anyone have any ideas? as others I know always claim they have smooth gameplay.. they are not using plus.net
Cheers.
jberry
Do you get the same problems on all your XBox live games or just pro-evo? Also, have you made sure you are not on an overloaded pipe segment - see this for details.
Regards
Josh Berry
cheers Ross. I'll try disconnecting and reconnecting
Pro Evo 4 is the only game i use on xbox live
It's a known issue with the game.
The lag like problem should be fixed via a patch within the week apparently.
It often makes me wonder whether these games are ever tested online at all.
To improve things a little until the patch, try turning off crowd noise and I believe that the Bayern Stadium is probably the best to choose online - I think it's called that anyway. Apologies if it isn't as I don't have Pro Evo.
