Playing Eve-online after middnight - connection keeps droppi
I repeatedly have my game sessions dropped now I'm using PAYG service from PlusNet.
Has something changed whereby you are limited as to how you connect after midnight?
Dan
Just read some of the forums on dropouts
Can someone post a linky showing the outages and upgrades that PN are doing.
Thx
Dan
Damfoose
I have had 6 drops today where usually its been rock stable, almost got me ganked lol
iainmacmillan
have you changed anything in your setupHuh do you have a modem or router??
i play EVE a lot, and have not experienced any drop out since the last patch in May.
seems to have sorted itself out now.
jabb0
i have had 2 disconnects in the last 2 hours, up until recently (the past week i have had numerous disconnects) this game has run like a charm.
Any help greatly appreciated!
iainmacmillan
Have you tried checking under the Known Issues section of the EVE-O forums.......discos are talked about frequently. You may also need to clear out your cache folder, actually only the 87.237.38.200 folder found in EVE\cache\MachoNet\, this will make your system re-download it, incase there is corrupt data which can happen if you keep getting dropped, and don't close cleanly.
Other than that, it maybe an issue with your connection, modem/router, system, anti-virus, incomplete patches.........i could go on.
Is there a friend near you who can check his connection to EVE?? Could be a node issue in your area connecting to the datacentre hosting EVE.....
