Ping to 217.158.176.31:12203
I about to get adsl with plusnet. (I use isdn currently)
What pings do people get to mohaa? How about to 217.158.176.31:12203?
Malc
From my own +net account.
--- 217.158.176.31 ping statistics ---
30 packets transmitted, 29 received, 3% loss, time 29066ms
rtt min/avg/max/mdev = 18.916/21.046/26.117/1.321 ms
From a BTO account
Ping statistics for 217.158.176.31:
Packets: Sent = 30, Received = 30, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 31ms, Maximum = 36ms, Average = 33ms
Same for another server (212.42.10.244:12403)
+net
--- 212.42.10.244 ping statistics ---
30 packets transmitted, 30 received, 0% loss, time 29071ms
rtt min/avg/max/mdev = 17.857/20.050/29.595/2.021 ms
BTO
Ping statistics for 212.42.10.244:
Minimum = 30ms, Maximum = 37ms, Average = 32ms
Roundtrip time to 217.158.176.31, average = 70ms, min = 70ms, max = 80ms
ed: should have said I'm sending 1024 bytes per ping so higher pings than normal
hmm Claranet routing is causing occasional packetloss to that server and higher pings
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
Firejack
Pretty good results to that particular server it seems Smiley
C:\ping 217.158.176.31
Pinging 217.158.176.31 with 32 bytes of data:
Reply from 217.158.176.31: bytes=32 time=19ms TTL=57
Reply from 217.158.176.31: bytes=32 time=20ms TTL=57
Reply from 217.158.176.31: bytes=32 time=18ms TTL=57
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Minimum = 18ms, Maximum = 20ms, Average = 19ms
Thanks all.
I am impressed at how helpful you all are.
Many Thanks
Malc
Gamers stick together Smiley
Phantom_Flan_Fl
Can't ping the IP as at I'm work but my MOHAA pings are usually between 20 and 50.
