Phantom console
Phantom console
Hi guys any one seen the specs for the up and coming console the phantom. Luks impresive as it dont have cds. An alwyas on broadband console . Luks good but will it do the business.
Phantom console
Never heard of it. Do you have a link?
Phantom console
it will fail
Phantom_Flan_Fl
Phantom console
Done a quick search and found this on the BBC website.
Unfortunately I can't access a lot of the gamer sites that talk about it because the firewall here at work blocks the sites.
Phantom console
It sounds to me just like a PC... :?
Phantom console
Worst of all, running on windows.
So while the fact you wont be downloading junk shareware to it, the registry will still clog - yuk.
Phantom console
yeah just will fail unlucky
Phantom console
The xBox already runs a cut down version of W2K.
Thomas
Phantom console
Other than usage information, key exchanges, saved games and updates, nothing much more is stored.
Remember, this console is going to be entirly driven by the HD.
My guess is compatability is going to be built in, so slightly changed but existing games will install.
Phantom console
Xbox live is the bomb any way . My ethernet cable broke lucky i have a a life time waranty on it other wise i would of paid a tenna not much but hey. sumert else i want 2 say i cant connect to online games on the pc. It says on one game that the rf tracker cant find any games check ya connection.
