Multiple Xboxes on live?
I have a Netgear DG 824M wireless adsl router / modem and have tried to run 2 xboxes on Live simultaneously without any luck. One of the connections gets dumped after 30 seconds to a minute. I do understand that connecting the two xboxes (with different live accounts / subscriptions) at the same time may not work due to the fact that I have only 1 external WAN IP address? Any help / advice on this would be greatly appreciated. Thanks in advance
Regards
Fraser
jberry
Hi Fraser,
You could request a block of 4 IP addresses (giving you two usable) if you are not able to do this with a single IP address - just request them through link:contact us.
Regads,
Hi
I will have a similar problem when my house mate registers his Xbox.
So if I request more IP addresses how will this effect my setup at home, we are using a US robotics ADSL router with 3 PC's and at the moment 1 Xbox but would like to make it 2. Once these extra IP addresses are active is it simply a case of plugging in the 2nd Xbox or do we have to configure the 2nd Xbox in some way?
Thanks and Regards
Pasive (Xbox tag if anyone see me on-line)
jberry
You would have to configure your router is such a way that the two XBox's had public IP addresses and the other machines had private IP addresses. I am not sure whether this would be possible using your router as I have no experience of using it.
You could try the ADSL forum or the manuafacturers website for help on setting it up.
Regards,
