MoHAA connection problem
I can ping the server but my MoHAA will not connect when you enter the IP and click 'Connect to server by IP address'. Does anyone else have this problem? Is the server passwd protected? If so, how do I config my MoHAA to work?
Am I missing something here?
Phantom_Flan_Fl
I could only see the 1 server running when looking through All Seeing Eye, the Free For All on 212.159.6.206.
That what you're trying to connect to?
I'm confused. The server info at the top of the forum gives different info than that? There is no MoHAA server with that IP address. I am trying to connect to 212.159.6.205:12204. I can get a ping from this server which suggests its up and running but cannot connect through MoHAA application.
Any help would be greatly appreciated.
It looks to me like 212.159.6.205:12204 isn't running at this time. If you look at the PlusNet server list you will see that server 212.159.6.205 is also running a Call of Duty server, which is why you can ping it.
Scott.
Phantom_Flan_Fl
Just to say the server I quoted is there and it's been full all day.
Below is a screenshot from my All Seeing Eye.
jberry
There should also be a second medal of honour server running. I'll have a look at it later on now that I have noticed this post Wink
