Minimum speed for xbox live
OK I can't get 2mb in my area so stuck with 1mb is this enough for xbox live? Cry
Thanks.
MarkAngel
I would of thought that 512Mb is more than enough, let alone 1Mb!!!!
M
Yes it is.
128/128 is the min requirement...
You're on 1024/256
OK thanks for the reply. i just feel cheated a bit because everyone is getting upgraded for FREE and I am missing out due to the length of my line. Whatever, that means?
It means, they would upgrade you, but you can't 'phsically' get 2mb.
If they did upgrade you, your connection may never sync again, or drop randomly (i.e. Not work)
Well i can run 2 xbox over live with my connection at the same time. So 128upload is really the min
