MOH ping rates
MOH ping rates
For the past couple of nights I've noticed higher than normal ping rates during gameplay.
Usually getting between 10-50 but now 70-160, mainly UK servers but seems laggy.
Have just replaced hdd recently and installed XP instead of ME on old one, but cant see that playing a part, speed tests look fine too.
Any ideas welcomed
Ja
1 REPLY
RE: MOH ping rates
Have uchecked the multiplayer settings to make sure the connection rate is on xdsl. iF it is then it could be a case that the servers you go on are slow anyway
