MOH Spearhead
MOH Spearhead
Hi all
Im not new to gaming online but I am new to this community kinda stuff!! basically i have been playing spearhead using Gamespy - but I undertsand their are benmefits to using these dedicated servers. Im a Plusnet broadband user and would be well worthwile on your MOH team so please if anyone can offer some help or IP tips pls do so.
Rgds
Fan
jberry
RE: MOH Spearhead
At present, we do not run any spearhead servers - only classic allied assault. The reason for this is that the linux (and windows but we are reluctant to use windows servers. Once bitten...) server for spearhead is very buggy and uses an incredible amount of processing power compared to standard MOH:AA.
This means that we simply do not have the hardware to run it. I am waiting on EA to sort the problems before I even consider this.
As an aside, the normal MOH server is down at the moment for a hardware upgrade but due to a couple of problems it will be next week before this is back up Sad
Regards
Josh
PlusNet Customer Support
Phantom_Flan_Fl
RE: MOH Spearhead
Thanks Josh,
I came in here to ask just that. Servers had been down for a couple of days.
Dave.
