Least amount of speed u require 4 xbox live?
My mate thinks he has tiscalli broadband x3 is this enough 2 use xbox live. I guess with this low speed he cant host games just join.
What's his upload speed? That's the real question.
I think it 64k upload as he is on the 3x broadband 150k download. I dont think this is enough but other people say u can
jberry
When we resold the tiscali lower speed products the upload speed was 256Kb on the 150Kb product so it may be the same in this case. If it is 256 then you will have no problems, with 64 it may work but you will see some problems.
Regards,
[Moderator note (by acarr) : Removed dupe reply]
