Kill the TFC and replace them with DoD instead
CallumW
Every time I check the TFC servers they are empty so I'd like to suggest that they are replaced with Day of Defeat Servers
This is another Half-Life mod which is now so popular that it is being released by Valve very shortly as it's own Retail stand-alone version in exactly the same way they did with Counter-Strike
You can get more information on the Modification here:
http://www.dayofdefeat.com/
and
http://www.planethalflife.com/dod/
The Mod is free and when the Retail version is released there will be a free upgrade made available to make current installs compatable with the retail version.
If you have the mod installed and want to try it out then you are more than welcome to connect to the following server and give it a go (note: Bots
(non-human) have a ping of 5)
I.P. 66.208.101.190:27015
Password: tna
Note: The above server will automatically be upgraded to the retail version within 24 hours of the release.
The Clan's website is:
http://www.TNAClan.co.uk/
CW
RE: Kill the TFC and replace them with DoD instead
The reason that we do not run any other mods is simply because of the hardware limitations. All of the new halflife mods (DoD etc) use nearly twice the processing power of the 'old' mods such as CS and TFC.
As such, at this time, it is not possible to change the servers.
Regards
Josh
PlusNet Customer
Re: RE: Kill the TFC and replace them with DoD instead
So, if the servers aren't being used and you're not changing them, why run them at all?
Neil
