Is gamefiles.frag9.net still available/working?
Header says it all really.
No response to ping or browser.
Phantom_Flan_Fl
I tried it on Boxing Day and it was down then.
Have to wait for Josh to check.
jberry
I am afraid it is currently down .. I have been away from a PC for a week now (god forbid) so have only just noticed. I will have a look later today.
Regards,
jberry
Right, I am not going to get this back up and running today. You will have to bear with me. I should get it back tomorrow.
Thanks for your patience.
Regards,
Still down - must be more of a problem than originally thought. Shocked
jberry
Back now ... I did fix the original problem just after Christmas but during my messing I managed to break one of the Ethernet cables (yep .. a broken cable if you can believe that). I didn't fancy coming in on my day off just to replace a cable (it was new year after all .. it's illegal not to go out of the pi**) so waited until my first day back Cheesy
Let me know if anyone has any problems.
Regards,
Phantom_Flan_Fl
Cheers Josh.
Can't actually check as I'm at work now.
Unfortunately it's a bit late for me as I had to download Americas Army 3 times in the last week after a couple of reformats.
Same position as davebroon - at work and had to download ET from another site. :roll:
Will check server access tonight.
Thanks for sorting Josh. Smiley
Yep, I can access it fine now.
