High ping times on COD2
Hi
Anyone else experiencing bad latency when gaming? When I choose a server I see the ping time at around 40ms whenI get in the game I am running around the 120ms mark & the game becomes unplayable as I get killed by those with low latency ie around to 40-50 mark.
Any suggestions? I am on the Premium service.
TIA.
BTW I am on 8Mb about 500 yards from my exchange although I only get about 3.5Mb d/l even though the router says I am connected at 7.5Mb.
Snap, getting the same sort of thing, though there is a uk server that my clan play on and the ping to it is over 1200 and I cannot connect!!!
Server is 217.146.93.21:29960 seems to be a fairly good one, some intereting mods.
No idea who to contact to sort this out at there is nothing that i can find on the help system!
Not a happy bunny here :x
i found that problem when i used to play cod2 online but i found that by lowering my graphics slighlty it reduced my ping allowing me to play
jrgrahamcov
I would raise a support ticket making sure you have the ip address and port numbers of any affected servers.
Finally got round to putting a ticket in for it. Shockedops:
Apparently the server is using a non standard port number for COD2 and therefore does not get given the same priority as other common gaming ports
Take it all back, got a very quick response to the ticket and the port number is getting submitted for consideration.
Hat's off to the support guys.
all this port throttling is bovine excrement tbh and when you complain thay tell you to make the server hosting compaines change the ports that they use for the servers you wish to play on
no other isp is doing this to their customers so why is plus net and honstly i am having ping trouble on every server i visit join a 40 ms server get kicked for breaking the 200ms ping limt
Yup, just what I was told... :?
