Help setting up xbox live for dummies
Hi
I have a plusnet broadband account with adsl router (Solwise SAR110 router) connected to a netgear EN104 4 way hub which has a win98 pc and the xbox connected to it
When we try setting up the xbox, it says "IP not confirmed"
Can anyone help with step by step instructions to get live up and running
thanks in anticipation
I'm sorry, I can't say I'm familiar with the x-box setup. But can you tell me - do you have dhcp active on the router?
how to set up the xbox
this is easy
Set your IP's to
192.168.7.2
255.255.255.0
Set your DNS to
212.159.11.150
212.159.13.150
Set the Gateway to
192.168.7.1
ADV: Allow binding to ATM = YES
thanks very much for the advice and help - will try settings tonight Smiley
If you manage it.. my gamertag is RIPPPER ( note 3 R's)
cheers
Xbox Live is the bomb.
