Game Pings
Game Pings
I was a little concerned when I read about slow connections etc. Well so far I have been averaging between 50 and 150 depending on the server. And that's the same as mates on BT, Freeserve.
So far very impressed with connection speeds!
RE: Game Pings
you can get better pings by tweaking the game settings, say for UT or UT2003 set you Netspeed too:
6000 on a busy/laggy server
8000 on a fastish infrequent lag server
10000 on very good server
20000 ONLY for lans
ADSL @ 288/576 Self Install
IRC.UTCHAT.COM
Usually in #utgames #UT2003
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
RE: Game Pings
> 20000 ONLY for lans
This is somthing I was not aware of. Does this work on MOH:AA too?
Myself, and my farther use MOH online, but I find that it can somtimes be choppy, when my farther has a download in progress, even if it is only downloading at a rate on 4KB/s.
I am unsure of what my current setting is, but I will look into that tonight.
Would this allow for better connection performance then?
