Galactic Command Corrupted?
Anyone successfully dowloaded and extracted galactic command from the repository? I get the following:
Extracting GalacticConquest0.21setup.exe
bad CRC 4fba0ab2 (should be 64022125)
I've downloaded twice now, same error.
Kind Regards
Tim
jberry
Is that error generated when you are unzipping the file or when you try to install it? I have sucessfully downloaded and extracted it here - although I cannot test the installation of it since I don't own the game.
If it is during installation then I'll re-upload it at some point in the near future.
Regards,
It's when I'm unzipping.
I've succesfully downloaded and installed from fileplanet now (there's also a patch out as well which can be obtained from there).
Kind Regards
Tim
