F.E.A.R
F.E.A.R
Hi was wondering if anyone can help i downloaded and installed fear fine. When i go to play i get (unable to initialize the renderer to a valid video mode) anyone know why Cry
F.E.A.R
What graphics card have you got? And which drivers are you running?
F.E.A.R
Dunno Shockedops: how do i find out
Shockedops: Shockedops:
F.E.A.R
Hi
You could right click on your desktop > select "properties" > click on the "Settings" tab > click on the "Advanced" button. > You should find a tab with info on your graphics card and it's driver release info.
F.E.A.R
Hi thanks for replying
when i do what you suggested it says information not available so i went into device manager and under other devices with a big yellow question mark i have
multimedia controller
pci simple communications contoller
video controller
video controller(vga compatible)
strange this requires further investigation
:shock:
F.E.A.R
Sounds like you have not installed the cards driver then and must be running on the windows default graphics driver by the sounds of it.
F.E.A.R
Hi i reformated comp on monday and it looks like all the drivers wernt reinstalled cos when i loaded the disk it said important updates to be installed so hope this fixes it thanks
F.E.A.R
yep hadnt installed drivers DOH Shockedops:
F.E.A.R
Hehe! Glad you're sorted now. Wink
