Counter-Strike:Source server help
I've been running a Counter-Strike:Source server for a while and I was checking out the plusnet server a couple of days ago and stumbled across the stats. I would really like to know how to set up these stats on my plusnet hosting that came with my connection. I tried to do this myself but had the following problem:
On attempting to install using the perl install accessing using telnet to my cgi.yourname.plus.com I got as far as actually loading the core and then I got an error claiming the server didn't have enough memory (which it claimed to be asking for 20 bytes)
Basically what i'm after is a walkthrough to how I can set up stats [p.s my CS:S server is on a different ip to that of my web hosting (obviously)]
Any help much appreciated
(My server 84.92.124.111:27015 only up between 4pm and 6pm at the mo)
you win32 ? or linux ?
i'm running the server on a win32 machine and hoping to host the stats on my plusnet webspace
Sorry dude never set it up on windows before.
I assume you have got your Mysql php etc all setup ?
Do you mean mysql/php on my plusnet server?
I do if thats what you mean
